It is currently Sun Jun 07, 2026 2:30 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 14, 2003 2:25 pm
The burn mark between 3 and 4 is only between the two cylinders and doesnt extend beyond that. I don't believe this is going to affect anything other than your compression between the two cylinders.
Since you mentioned all the buildup of crap you had to scrape out. If this was plugged, it is probably enough to cause backpressure in the crankcase, forcing the oil into the intake manifold.
I'm betting that as long as your head isn't warped, you can slap this thing together and be up and running. From the pics, the internals look pretty clean to me.
It was probably a benefit pulling the head and seeing that scorch mark so you could replace that head gasket before it went completely out. ;)
 Post subject: agh
PostPosted: Sun Sep 14, 2003 3:33 pm
agh yes, of coarse, i do not regret taking the head off, now i know that it aint bad in there, and as you say, replace the gasket before it got worse, And as i had mentioned, I got to expand my tool set!!!
