It is currently Mon Jun 08, 2026 7:05 pm
 Post subject: Help
PostPosted: Wed Feb 07, 2007 9:01 pm
ok i just got done putting a motor in the luv and i've hooked up alot of the ecletrical execpt every thing i try and then hooking the battery up. the battery termanels spark and then the voltage regulator starts smoking i don't know why it's doing it any suggestions or pics would be helpful.
PostPosted: Wed Feb 07, 2007 11:46 pm
I hate to state the obvious but make sure you don't have the battery terminals reversed. after that unplug the voltage regulator and make sure everything else is fine. then plug the v reg in again. Voltage regulator on the luv is mechanical with relays so something might be stuck in the wrong position. Wack the cover of the v reg a couple of times with the handle of a screw driver. I made one work by doing that once.
Only other thing might be you wired something wrong on your alternator. were you doing anything with it lately?
any other hot voltage wires pinched to gorund might also be the problem
Current Fleet
pics
PostPosted: Thu Feb 08, 2007 5:18 pm
i fugured it out thanks it's ALIVE!!!
 Post subject: Positive and negative
PostPosted: Thu Feb 08, 2007 8:15 pm
LOL
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Feb 09, 2007 1:19 pm
What was the problem? Just in case I run into
'smoking regulator syndrome"
Current Fleet
pics
PostPosted: Fri Feb 09, 2007 3:20 pm
PITA Old Fart
It was probably that dreaded ID10T error...happens with the newbies & the young members all of the time.
So ya better get used to it around here...lol
