It is currently Sat Jun 06, 2026 11:52 pm
 Post subject: Air Adjuster?
PostPosted: Wed Apr 16, 2003 9:29 pm
There is something that looks like an adjuster bolt under the air filter. Does that adjust the air that comes in or, what is it for?
PostPosted: Wed Apr 16, 2003 9:56 pm
from my dads 74 thats to lossen or tight that thing that goes on top of the carb. in order to take it off to see the carb.
 Post subject: Air Adjuster Reply
PostPosted: Wed Apr 16, 2003 11:03 pm
Mine is an 81, 2.2 , Diesel. Where would it be on that?
PostPosted: Wed Apr 16, 2003 11:52 pm
u dont have that
 Post subject: Reply to Air Adjuster?
PostPosted: Thu Apr 17, 2003 1:40 pm
So what could that adjuster bolt be that is under the air filter cartridge?
There is a line that goes from the motor to where the air comes in. What is that line for?
PostPosted: Thu Apr 17, 2003 2:07 pm
then im not too sure on that.
PostPosted: Thu Apr 17, 2003 3:37 pm
I think your talking about the little adjuster screw that handles the heat riser valve. It controls the flapper valve that allows either heated manifold air or normal air to enter the motor. It's been a while since i've had to deal with one but basicly, thats how it works.
PostPosted: Thu Apr 17, 2003 6:12 pm
Are you guys are talking about the bolt that tightens the clamp around the carburetor throat?
PostPosted: Thu Apr 17, 2003 6:38 pm
yeah dkay i was talking about that but if other than that i dont know.
