It is currently Mon Jun 08, 2026 2:29 pm
PostPosted: Sat Aug 05, 2006 12:45 pm
Well, i my dad found a running 86 PUP in a junkyard a few weeks ago that he thought i might be interested in, he finnally got pics of it and i'm kinda sold on it, but i was wondering if the 2.3 in it is worth getting? Oh and it has AC and a lift gate in the back... all for 300 bucks... ya'lls opinion plz
PostPosted: Sat Aug 05, 2006 1:45 pm
hell i would get it just for the a/c and the lift gate. if all else fails you could sell the a/c stuff and the lift gate and probably get your money back.
PostPosted: Sat Aug 05, 2006 4:28 pm
yes, get it or i will ban you... :lol:
PostPosted: Sat Aug 05, 2006 8:26 pm
Banishment Pending
Yes the 2.3 is worth it, becasue you can swap it out for a 2.6 :twisted:
Get it or I fly over there and kick you in the nuts for not getting it :D
PostPosted: Sat Aug 05, 2006 9:40 pm
Lift gate??? Does it come with ballast weights for the front bumper, like a farm tractor? :lol:
PostPosted: Sun Aug 06, 2006 5:43 am
I could make them... but no, it's got a gigantic slab of steel in the bed though...
And i'm gonna look at it thurs. morn and put a batt. in it and take a look at the flats on it, then i'll probably give them the cash fri. aft....
Oooohhhh, scary AF guy, geuss i'll have to get it just to stay in the "informative" thread.
PostPosted: Sun Aug 06, 2006 9:51 am
Boooo scary Air Force Guy...
Hooray Beer!!!
300 bucks for a running truck? People have paid more for less.
PostPosted: Mon Aug 07, 2006 2:38 pm
Don't want it now, interior is pretty much trashed, engine runs good though. Need's motor mount, Tune-up, there's a brake fluid leak somewhere... it's got brakes but they go down toooooo far, clutch needs adjusting badly, needs: valve cover gasket, frt. main seal, muffler/exhaust, they cut the lift gate off cause it didn't work, ac doesn't work, pwr str. doesn't "feel" right, need's a coolant flush, odd's n' ends'... i don't want to spend 300 bucks on the truck and have to spend alot more later to keep it around. At least the head isn't cracked and it cranks right up. idk, might pick it up later on in the year and drop the motor in another truck.
BTW, why's the dist. in the back of the motor? what's different about this 2.3 and the g-sieres motors?
PostPosted: Mon Aug 07, 2006 6:56 pm
Hey, heard about this truck from your dad over on the Isuzu PUP forum and didn't sound like too bad of a truck. Sorry to see you aren't going to get it. He also said it needed a tune up and one motor mount was bad over at the PUP forum. Even if you do plan to get it later on you could always drop in a diesel engine. That's what I was telling your dad about if you guys did happen to get it.
Salvy
1982 Chevy LUV diesel
2.25" stainless exhaust
w/ MagnaFlow performance muffler
PostPosted: Tue Aug 08, 2006 4:16 am
Well, it's just not worth getting it right now if i'd save up 300 to get it instead of blowing most of my check this fri. to get it, then it wouldn't be much of a problem to get it and tinker with it.
PostPosted: Wed Aug 09, 2006 12:04 am
Dist runs off a gear on the camshaft instead of the oil pump/crank like the G series. The 4Z series (2.0, 2.3, and 2.6L motors) stuff uses a timing belt instead of a gear, so there wasn't a convenient place to hook the dist up front. It also gives a lot more room for power steering pump, AC compressor, and such. In short, there is a lot of stuff that is different between the two motor families. Almost no major parts interchange, but much of it is similar.
PostPosted: Tue Nov 14, 2006 6:56 pm
Hey Finalman.
I am in Gibsonville, NC.(just East of Greensboro near Burlington)
There don't seem to be too many other Diesel owners out there.
I have an 82. Hopefully I can keep it running for awhile.
There are alot of things I'd like to do to it but I am new to working on a diesel.
PostPosted: Tue Nov 14, 2006 11:00 pm
Banishment Pending
PM next time please, don't need to bring up old posts and get them off topic
PostPosted: Wed Nov 15, 2006 1:21 am
would be a good work horse
Im luvin it
