It is currently Mon Jun 08, 2026 1:14 pm
 Post subject: brakes
PostPosted: Mon Oct 02, 2006 5:43 pm
Ok, so when i drive they squeek, not all the time, when going slow you can hear it is just in one spot. But when I am on the brakes they dont sqeek. any ideas?
Most people think of their skin as an ally. Makes me rethink having skin at all
PostPosted: Wed Oct 04, 2006 11:16 am
Front disc?? Are they worn out? If they are fairly new, was the pad glue stuff applied correctly? A common mistake is not letting the glue dry enough before installing the pads.
PostPosted: Wed Oct 04, 2006 4:25 pm
ya, they are disc, sorry, and i did put the glue stuff on them i think it was maybe a shade under a year ago. Knowing me, i might of not let it dry. Could I just pull em off and redo it? And do I need to scrape the old off?
Thanks,
Nick
PostPosted: Wed Oct 04, 2006 5:27 pm
It's worth a try. I've had something that simple be the problem before.
If it just started squeaking, leave it alone for a couple weeks. Sometimes it's a hard spot or dirt in the pad and it will go away on it's own. (although that is usually a squeak when applying the brakes).
PostPosted: Wed Oct 04, 2006 9:13 pm
ya so its been doing it for a few months but I only really drive it on weekends and I always say that ill fix it next time i get back to my parents place where i can actually work on stuff. and it never happens. Thansk for the advice
Users browsing this forum: Baidu [Spider] and 44 guests
