It is currently Mon Jun 08, 2026 8:38 am
 Post subject: 4 High problem
PostPosted: Tue Oct 11, 2005 8:20 pm
dose any have a problem with there four high mine slips out and gose to to two high
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Tue Oct 11, 2005 11:28 pm
now that you mention it, it happend to me once when i first got my truck but i havnt noticed it since then
PostPosted: Wed Oct 12, 2005 3:17 am
My first 79 used to do that. It was the shifter hitting the body. It had a 2 inch body lift and the hole around the shifter had not been opened up enough to clear 4HI all the time. Also liked to jump out of 4LO when I was backing up. A little cutting and grinding fixed things up though.
I've seen it once or twice in stock height 4x4s that I test drove too though, usually when the 4x shifter boot was not stock or was not stuck in the hole right.
PostPosted: Wed Oct 12, 2005 7:50 pm
whats a good way to fix it
79 4x4 1.8 liter
