It is currently Mon Jun 08, 2026 9:53 am
PostPosted: Fri Jun 03, 2005 5:36 pm
Alrighty last night i was driving around whith all the accsesories on (fan motor on high lights on and turnsignals on) And i noticed that my GEN light came on super dim and pulsed in time whith the blinker. Well i took a multi meter to the batery and it was reading just shy of 14volts when the motor was running and about 13.5 whith the motor off. Thats perty standard. So i had my alternator checked and it checked out as good. Could this be a small amount of a voltage regulator problem manifesting? My front blinkers are aftermarket ones for trailers so they draw some amperage i suppose (they blink slower than the stock ones did). Thanks for the input.
PostPosted: Fri Jun 03, 2005 9:34 pm
well i tested the voltage regulator and everything checked out except it pushed 15.2 volts insted of 14.8volts. So its a little high. Could this be a side effect of the electronic ignition?
PostPosted: Sat Jun 04, 2005 4:23 pm
I would not think the ignition would factor into the charging system much. The thing that finally got rid of the slight glowing gen light on my 77 was hooking up grounding straps from the motor/trans to the cab. Could be you just have a loose ground some place on the truck. Apparently, bad grounds in the cab/body like to leak back through the charge light and cause it to glow a bit. Mine tended to get brighter with the heater blower turned up but it was always on a bit unless everything was turned off.
PostPosted: Tue Jun 07, 2005 6:07 pm
well its glowing realy dim randomely sometime now. When i started the truck it was on and then i hit a bump and it turned off. I was beginging to suspect a bad conection. I guess ill check that ground strap, last time i pulled the motor i seem to remeber it beeing in bad shape.
PostPosted: Wed Jun 08, 2005 4:17 am
Where is this ground strap that you speak of ? I should probably check mine on the '79. I had the same exact glowing that XL speaks of and it did it the same way, was not there when everything was off, but got brighter when heater was turned up. Now the truck won't start at all, battery is fine, just no juice to anything, not even the dome light. Completely dead. So I am guessing bad connections somewhere. Any suggestions would be appreciated. Thanks.
http://www.purerockradio.net/
PostPosted: Wed Jun 08, 2005 8:21 pm
I've got the same problem on my 79. In the process of restoring it now and thinking of replacing all the grounds while I've got it apart.
PostPosted: Wed Jun 08, 2005 10:42 pm
the strap comes from the shifter tower to the body in tranny tunnel.
PostPosted: Sun Jun 12, 2005 8:59 am
If you don't want to crawl under your truck to check it out, just buy any old battery cable and bolt it on somewhere. You can put it under the hood somewhere from the eng. block to anywhere on the body. If the original down on the trans. is still good, You won't hurt anything by having an extra ground wire.
PostPosted: Sun Jun 12, 2005 11:37 am
Yeah it sure don't hurt to have more than one good ground. I tied the harness in the back to the frame and the bed, replaced the trans tunnel wire, and hooked the block to the firewall just for good measure on my 77. You can pick up a short battery cable with bolt on tabs at both ends fairly reasonable at most parts stores. Since its not running full starter power through it, you could use a small cable like what you might find on a riding lawnmower too.
PostPosted: Tue Aug 09, 2005 6:01 pm
well i didnt encounter the problem untill here recently. But heres the wierd thing, that wire that 800 spoke of is intact but was resting on my header collector. The second i got it off the collector no more problem. But this dont make sense becouse the electricity should still ground out point A to point B, even if a point A and 1/2 is introduced right? Well anyway i think im going to replace that wire soon.
PostPosted: Wed Aug 10, 2005 8:59 am
by the looks of your motor your collector is powder coated right? Well the coat would probably still conduct electricity but then would have some resistance to it therefore it wouldn't totally ground through it.
PostPosted: Thu Aug 11, 2005 2:42 am
yeah but the wire is still intact A to B so thats why im confused...
PostPosted: Thu Aug 11, 2005 6:59 am
corrosion b/w point A1/2 and B maybe?
PostPosted: Fri Aug 12, 2005 1:08 am
yeah im thinking the fittings on the ends are shot and me just moving em around renewed the connection. Im replacing it this weekend.
PostPosted: Wed Sep 21, 2005 8:24 am
Heat=resistance. Having wiring too close to your exhaust would impede the current flow and cause trouble in the circuit via your ground strap. I've had similar problems with cables, wiring, etc. exposed to too much heat around exhaust, heaters, the radiator, etc. When the temperature goes up, some wild electrical stuff happens sometimes because of a drop in voltage due to increased resistance from the heat applied to the wire. The same thing can happen if you use too light of a guage wire. As the wire heats up from trying to handle too much current, the voltage drops at the same rate and the output gets weaker and weaker. That's why it's always important to use heavy guage wiring, watch where the devil you route it, and throw in a few extra body-to-chassis ground straps just for good measure.
Maddening stuff, huh?
PostPosted: Wed Sep 21, 2005 9:11 pm
yeah i have the thing fixed, i ran a ground strap for a battery from the aternator mounting braket on the front cover to the brake cylinder holding braket. No problems since and its not in the way of anything.
