It is currently Mon Jun 08, 2026 8:39 am
 Post subject: clutch cable
PostPosted: Mon Sep 12, 2005 1:11 pm
How do you unhook the clutch cable from the trans.? I cant pull enough slack in it. Would it be easier to pull trans. at the same time, or motor first? I'm just doing a stock engine swap. Thanks all.
 Post subject: Cable
PostPosted: Wed Sep 14, 2005 1:21 pm
You introduce slack into the cable on the engine side of the firewall where the adjusting nut is on the cable housing.
PostPosted: Wed Sep 14, 2005 2:10 pm
Yeah, you start at the top. Adjust the cable so that it has slack, take it off the pedal, then you should have enough slack at the bottom to take it off there.
