It is currently Sun Jun 07, 2026 1:12 am
 Post subject: help !gas in oil pan
PostPosted: Mon Jan 27, 2003 5:00 pm
gas in oil pan :roll: Can someone please answer this question ?
its not much but i can see it evaporate on a cloth, 1.8 engine good running little truck, 4x4 79 you can answer here or email me at dawnc@semo.net
I was told it was a leaking jet, ill take $ 400.00 for this 79 4x4, its all there even the crank for the spare tire underneath. 4x4 all works great. cab mounts ate up, but runs good, no smoke ! has a 4 speed
I live in Patterson Missouri, its about 45 minutes north of Poplar bluff !
PostPosted: Mon Jan 27, 2003 9:33 pm
It's more than likely the needle and seat inside the carb. Not the jets. Jets can't leak, they only meter the fuel.
When everthing goes wrong....
What's right is what's left.
PostPosted: Tue Jan 28, 2003 10:21 am
that will age your cylinder walls quickly. Carefull.
PostPosted: Tue Feb 04, 2003 11:20 pm
could b the fuel pump leakin if its not electric
