It is currently Mon Jun 08, 2026 7:23 am
 Post subject: alignment specs
PostPosted: Wed Jul 13, 2005 9:40 am
Luvtruck.com Wookie
i have a hayne's manual for my truck, but it gives odd specs for toe in and caster /camber.
who knows the spec for toe/ caster /camber on an 80?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Jul 13, 2005 6:49 pm
I have a book at the shop that I work at that has the specs I will try to get that Tomorrow for ya
Jim
`79 LUV 2WD Stocky
`80 LUV 4WD Stocky
PostPosted: Wed Jul 13, 2005 8:36 pm
if you are looking to reset due to a parts change... here is the book numbers
camber + or - 1/2 degree
caster + or - 1/2 degree
toe-in + or - 1/16 inch
camber (side to side) 1/2 degree
caster (side to side) 1/2 degree
caster and camber must not vary more than 1/2 degree from side to side
toe in setting must always be made after caster and camber
if you are looking to check it for correctness the service checking numbers are as follows:
camber + or - 3/4 degree
caster + or - 1 degree
toe-in + or - 1/8 inch
camber (side to side) 1 degree
caster (side to side) 1 degree
PostPosted: Fri Jul 15, 2005 6:36 am
Luvtruck.com Wookie
thanks bob......some idiot at les schwab didn't tighten my upper control arm properly and i didn't discover it till all the shims were gone and it killed two tires and a set of wheel bearings.
on a side note...... i scored a set of stock 15x6" rodeo rims and stuffed a set of 215/60-15 on em and man....it looks sweet......have to get used to inproved handeling.... i'll post a pic of rims and tires later today.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Fri Jul 15, 2005 7:41 am
welcome.... :wink:
PostPosted: Fri Jul 15, 2005 3:19 pm
1) So does that mean the 'ideal' settings for camber, caster and toe are all 0?
2) I've searched the forum but didn't see. Does anyone know what the offset is on a stock wheel? (Mine are all gone long ago.) I assume it's got some negative offset, if the toe is zero.
3) If I'm running a 0 offset wheel, should I dial in a little toe to compensate?
You went there in that?!?!
