It is currently Mon Jun 08, 2026 2:14 am
PostPosted: Tue Jun 21, 2005 11:05 pm
Traced the tail light not working to the headlight switch.
I'm pretty sure, ran power through each post on the switch-- headlights work, front turn signals work,
side markers work
Is there a source for just the switch?
Where can I buy one?
Thanks in advance
PostPosted: Wed Jun 22, 2005 12:34 am
I doubt you'll find them new anywhere that will just plug right in as a direct replacement. You can probably find one in a junkyard, and I believe Isuzus up to the late 80s have the same wiring scheme and basic size/shape.
I've also been able to clean them up inside and get them working again. You bend the tabs up and the back pulls off. Careful as you open it up as there are some loose bits in there. Clean the contacts up and give it a very light bit of grease (vaseline would probably work fine) and see if that helps.
PostPosted: Wed Jun 22, 2005 3:03 am
thanks for the info.
I will let you know how it turns out!
PostPosted: Wed Jun 22, 2005 8:11 am
The one in my truck is from a trooper, 85ish??, and was a direct swap...good luck
Resident lurker
PostPosted: Sat Jun 25, 2005 2:50 pm
Thanks for the swith cleaning advice...... it worked well.
Tested the switch it now works well.
On to another trouble spot.....Wiring? Rear Plug? Harness?
Any help , Ideas are welcome
