It is currently Mon Jun 08, 2026 2:10 am
 Post subject: Carb Help
PostPosted: Tue Oct 07, 2003 10:13 pm
Ok, how do i re-ajust my carb so the mix anint so rich? i am thinking about getting a 4 barrel carb? is it worth it? other then that thats about it...plus do proformance spark wires exist?
it just seems like there is proformance this and that...
Thanks,
PostPosted: Wed May 04, 2005 8:27 am
If you still have the Hitachi get rid of it and get a Weber
1980 Chevrolet LUV stock 1.8L longbed
1980 Chevrolet LUV parts truck shortbed
1983 Suzuki Gs550 Sportsman
1989 Nissan King cab P/u <totalled> 4/1/06
1986 Full size Chevy P/U
1993 Volvo 850 GTL
PostPosted: Sun May 08, 2005 2:00 am
ya webers r so much better
 Post subject: Mixture
PostPosted: Sun May 08, 2005 8:56 am
Ideally, turn the high speed mixture adjustment screw in until the engine idle becomes rough. Next, turn the screw out until the idle becomes rough. Finally, set the screw halfway between the two rough points. Should be about 2 1/2 turns out from all the way in.
