It is currently Mon Jun 08, 2026 1:02 am
 Post subject: transmission problems
PostPosted: Thu Feb 03, 2005 9:18 am
Luvtruck.com Wookie
i had my 4 sp fall apart after i rebuilt my engine earlyer this summer.
after i did the motor i immediatly noticed that the trans had a grinding noise when the clutch not pressed in...... it blew 4th gear and i dropped a 5spd in.
my 5 made the same noise when i put it in but was slightly quieter..i've scoped the trans out and the noise is definetly coming from the input shaft.
now it's making a clunk(rotating) and whines BAD during acceleration.
before i rebuilt the engine it was quiet.........and the 5 was dead quiet when it was in the p'up
the only thing i can think of is maybe the pilot bearing didn't seat all the way.
is this a possibility? i need to rebuild my trans already and i don't want it to happen again.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Fri Feb 04, 2005 2:28 am
With the clutch out the pilot bearing should be sitting still in relation to the motor and trans, in gear or not. Seems to me that should rule it out unless the noise shows up only with the clutch pushed in. Same thing with the throwout bearing for the most part, tho it can freewheel a little with the clutch out. Seems really odd to have two trannies do similar things, I keep thinking things like I wonder if the motor/trans is lined up right. That would stress the input shaft and cause whine/wear in the bearings. It should also be eating up the pilot bearing pretty fast too though.
If the pup had been sitting for quite a while it could just be wear showing up from bearings that had run dry or something. That doesn't account for the 4spd going in similar ways though. If it did sit a while, it would be worth getting it good and warm and changing the fluid. Might be some stuck on gunk that has come loose with newfound activity.
I guess I don't really have much of an answer, but maybe this gives you something more to think about. The trans in my 77 2WD has whined fairly loud under load in 3rd gear since I put it together some 14-15 years ago. Never has gotten any worse. Changing the fluid often does help, and if you are not in a really cold climate you could give it 90W. I've had a trans that was run with it for years before I got the truck and it didn't seem to suffer any ill effects. Never know though, so I've just stuck to the recommended 30W motor oil.
PostPosted: Fri Feb 04, 2005 7:56 pm
Luvtruck.com Wookie
i do know that when the 4 spd went out it was throwing itself out of fourth and i had to force the gearstick, i'm pretty sure that the input shaft was still spining even though the clutch was fully disengaging.
i swear that when i first rebuilt the motor the crank had a pilot bushing not a bearing.....
who has a pilot bushing/bearing laying around that they could spec? i'm gonna tear the tranny out this weekend and replace the front and rear seals and the front bearing..... i'd hate to do all that work and have it just go out again....
for the record the 5spd was a running truck and i drove it around for two months before i stripped it.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Tue Feb 22, 2005 5:09 pm
could be the rear end i just scaned over it real fast so i dont know if i missed somthing
