It is currently Sun Jun 07, 2026 11:52 pm
 Post subject: Windshield visors
PostPosted: Mon Jan 24, 2005 12:10 pm
I need a new windshield visor. I broke the plastic mount. Will the Trooper visor mount ok? How about an S10?
 Post subject: Re: Windshield visors
PostPosted: Mon Jan 24, 2005 11:26 pm
I tried one out of a Dodge Dakota, it might work with some modification.
the main post is a little bigger, and I think the pattern that that bolts the triangle shaped base to the roof is off a little.
PostPosted: Tue Jan 25, 2005 1:16 am
My 86 Trooper has the same plastic mounts. The visors themselves look longer so they probably would not work, but the plastic mount should fit. I've been thinking about a rework idea on these for a while, having going through a few of them myself. I think if you cut out a piece of sheetmetal and backed the broken plastic with it it would just about work, except that the shaft doesn't go through at a right angle. Maybe somebody will figure out how to cast a replacement out of aluminum or something.
PostPosted: Tue Jan 25, 2005 10:32 am
Yes the trooper's will fit.
Funny you should say that about the aluminum 800xl, reminds me that I have to check and see if the machine shop has gotten anything done on mine... Not paying for it or otherwise having a set machined would be way too much $$.
Resident lurker
 Post subject: Windsield Visor
PostPosted: Wed Jan 26, 2005 9:47 am
I took the visors out of a Trooper for my 79 LUV. The visors were too long, but it only took about ten minutes to put the LUV visors onto the Trooper mounts. It's just a spring loaded nut if I remember correctly.
 Post subject: Visors
PostPosted: Wed Jan 26, 2005 3:37 pm
Okay, I'll check out the junkyard for a LUV or Trooper after all the mud dries out.
PostPosted: Wed Jan 26, 2005 5:37 pm
Robert, you will probably find out that the trooper is going to be easier to find the plastic deals in good shape. At least that's what I've seen. The only thing I haven't found with them is the color I want! lol But some good vinyl spray will take care of that nicely...
Resident lurker
 Post subject: Re: Windsield Visor
PostPosted: Thu Jan 27, 2005 11:45 pm
I tried the ones out of a trooper and when I had them both on, they overlapped. I guess you could cut them down?
Let me know if anybody has done this or something similar.
PostPosted: Fri Jan 28, 2005 11:05 am
Luvtruck.com Wookie
not to brake topic but.....
i've been thinking about that idea for a while.....visor mounts, interior door handles, that damn e-brake pulley.......
i have a friend that does injection molding but he's never worked w/aluminum......just peuter.
TiLtEd wrote:
Boobies!!! :D
 Post subject: Pulley
PostPosted: Fri Jan 28, 2005 11:58 am
Not to doubly change the topic, but I had a pulley crumble on me before and made one out of aluminum with a brass bushing on my Taig Micro Lathe in about 10 minutes. See if you know someone with a lathe and use some 2" aluminum round stock.
Rick
Loranger, La
1980 Stepside LUV (Again)
