It is currently Mon Jun 08, 2026 1:06 am
 Post subject: Stereo
PostPosted: Sun Jan 02, 2005 8:18 pm
I just got a CD player for my truck. I am going to mount it in the glove box, and was wondering if the power wire for the AM radio is powerful enough for the CD player? If not, how should I power it?
Also any one want to post some pictures of their radios in the glove box, and where they put the speakers?
Thanks
PostPosted: Sun Jan 02, 2005 8:49 pm
That wire should do... but that is a switched wire, meaning it turns power on/off with the key. You'll probably also need a constant power wire. Get a test light, and find a fuse with constant power, whether the key is on or off, and tap the wire and run it to the other wire to provide constant power for your clock and station presets and such. You can also run a wire straight to the battery, but that's not the "professional" way to do it.
Basically, the only wires you'll need is a constant power, a switched power (which you already have) and a ground (which you should already have)
You'll probably want some speakers other than stock too. Lots of people have put some 4" or so speakers in their door panels... but good door panels are hard to come by. A good, cheap setup would probably consist of some 6x9 speakers in enclosures behind the seats, and maybe some tweeters hidden around the dash. 8)
PostPosted: Sun Jan 02, 2005 8:54 pm
Standard aftermarket radio wiring...
Yellow wire - Constant/Battery Feed
Red wire - Switched Power Feed
Black wire - ground
:smt023
PostPosted: Sun Jan 02, 2005 8:58 pm
I already have speakers... 6x9 5 ways... They are pretty nice, and I think I'm going to get some more, when I get some more money...
I'm going to run a wire to the battery for the constant power (It has a fuse built in and that is where it says to attach it)
Just wasn't quite sure about the AM radio power.
Thanks for the info though... :D
Users browsing this forum: Bing [Bot] and 54 guests
