It is currently Sun Jun 07, 2026 11:53 pm
 Post subject: heater prob
PostPosted: Fri Dec 17, 2004 1:54 pm
the problem is it barely blows air out the bottom under the controls and nothing else works on it. thats pretty much all i can explain. and the fuse is good :?
PostPosted: Sat Dec 18, 2004 12:50 am
sounds like your fan is not working. i would start by seeing if the fan was actually turning (Mine has a bit of air that flows with or without the fan blowing). if it is not, check to see if you are getting power to the fan from the switch. if not, check the switch, etc, etc.
PostPosted: Sat Dec 18, 2004 1:03 am
If you can hear it come on, then check the tubing under the dash. I know mine was all tore apart and I had to kinda jimmy rig it all back together.
