It is currently Sun Jun 07, 2026 7:35 pm
 Post subject: Vacuum leak blues
PostPosted: Thu Sep 02, 2004 11:08 pm
OK. I had the carb rebuilt and put it back on. Runs bad ,won't idle. I plugged off everything and it runs bad, rough idle. My question. The egr seems to open and close when vacuum is put to the line, but is it possible that the egr valve is not closing all the way, or could it be letting outside air ,not the exhaust ,into the intake? Ron
PostPosted: Thu Sep 02, 2004 11:25 pm
Just in case I get the answer I think I'll get, Lil Blue, You have any egr valves for a 78?? Ron
PostPosted: Fri Sep 03, 2004 8:29 am
Mine wasn't closing all the way on my truck, so I just got a couple scraps of aluminum and capped the whole assembly in. Got a plug for the bung on the exhaust manifold and called it good. Just hope you don't have to emission like that.
1980 Luv Mikado 4X4
PostPosted: Sat Sep 04, 2004 10:45 am
Vaccum line blues is when you go to get your Luv smogged and the shop replaces 2 lines and a rubber seal on the gas cap, then charges 150 bucks on top of the cost to get it smoged. :cry:
PostPosted: Sat Sep 04, 2004 3:24 pm
Yea. I can relate. :(
PostPosted: Sat Sep 04, 2004 3:47 pm
I can relate. I just had my engine rebuilt and had a vacum problem. It's all good now though. :D
PostPosted: Sat Sep 04, 2004 4:45 pm
yep, i sure do have 8)
PostPosted: Tue Sep 07, 2004 3:47 pm
Banishment Pending
Narc. how did you plug off the egr? my truck has the same problem and i was woundering how you did that.
Users browsing this forum: No registered users and 76 guests
