It is currently Sun Jun 07, 2026 10:57 am
PostPosted: Sun Aug 08, 2004 6:35 pm
I just bought this thing about 2-3 mos. ago & sometimes when I drive the butterfly valve in the carb will open wide & the engine will die if you hit the gas & sometimes it will only run w/th valve wide open. what is up w/this, & what do I do to fix it w/o having to buy a new carb/webber or a rebuild kit?
 Post subject: luvluvr
PostPosted: Sat Aug 14, 2004 10:11 am
First check all your vacuum hoses to make sure you haven't a vacuum leak. Replace any questionable ones. Don't forget the hose to the brake booster. Then next rebuild the carb if necessary.
PostPosted: Sat Aug 14, 2004 6:15 pm
Also.. check the needle and seat... if trash gets stuck in it, it will mess up your fuel flow.
PostPosted: Sat Aug 14, 2004 6:46 pm
might also check out the points in the distributor and the condensor.
