It is currently Sun Jun 07, 2026 5:17 am
PostPosted: Sat Nov 02, 2002 4:44 pm
allright this time lets see if we can stay on the subject :x i asked earlier if i could use a 5 speed out of a 83 to 89 camaro i never really got an answer everybody was just interested that my clutch linkage was cable not hydraulic. but anyways im going to drop a mildly built 283 into my chevy luv i have read earlier if i wanted to use a 4 speed that i had to use a monza bellhousing with shifter fork and throwout bearing does anybody know if this camaro transmission will work or do i have to get the bellhousing and these parts in addition? thank you guys help will be greatly appreciated and by the was i love this site!!!
PostPosted: Mon Nov 18, 2002 3:04 am
As long as you can hook up the clutch and the shifter lines up, I don't see why it wouldn't work. It will bolt up to the motor and that's the important part. Everything else you can always modify to fit or fabricate something to work.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Thu Dec 12, 2002 9:21 pm
i have two different trucks with the camaro t5 in them i also used the vega cable clutch bell housing and they work great and i love 5th gear!
mike8cyl
