It is currently Sun Jun 07, 2026 7:20 pm
 Post subject: runs..doesnt run?
PostPosted: Tue May 04, 2004 9:56 pm
hi my 79 luv will run and sometimes when you stop and have the clutch in or the truck in neutral and the clutch out it will die. sometimes it wont. so sometimes it idales and sometimes it doesnt! what causes this? is it a crappy accelerater pump or what? any help would be nice!!! thanks
 Post subject: to run or not to run
PostPosted: Tue May 04, 2004 10:26 pm
Have you checked your fuel pump, and filters??
PostPosted: Wed May 05, 2004 7:30 am
open up the air cleaner and pump the gas. It doesnt have to be running.
See if gas is being squirted in when moving the linkage(pump the gas). Then acclecator pump is ok. Or ck the arm that pushes it. My weber DGV it was stuck(pushed in). I WD40 it and worked ok.
May ck dist if still running points for side shaft wiggle.But dont thats it.
Also ck the idle jet is dirty(on side of carb) should be a brass screw that holds it. Could be plugged and you will have to feather the gas pedal(running off accelerator pump) to keep it running).
Cut open your fuel filter to see if dirty. Mine was packed full of rust.
When your travling at say highway speeds its OK. Only at low rpm you have the feather the pedal that means run running off the accelerator pump. Its the idle circut that being plugged. Try blowing air, carb cleaner in there and open up the idle jet. Or if you have the idle cuttoff switch make sure the wire is getting 12volt to open the switch go gas goes to it or its plugged if the switch is working OK.
PostPosted: Sat May 08, 2004 11:02 pm
I'd say take the whole carb off and do a rebuild. Its a great way to eliminate a ton of problems associated with a plugged jet somewhere, sticking floats, or any of that other carb stuff. Not to mention it never hurts to have a fresh clean carb...
PostPosted: Sun Jul 11, 2004 11:13 pm
when you rebuild a card what does it intel because i am about to take mine down and rebuild it!!!! :D
PostPosted: Mon Jul 12, 2004 9:57 am
usually... depending on the quality of the facility you are using they will disassemble, solvent tank, replace all jets, gaskets, o-rings, accel pump, anti dieseling and coasting solenoids, and electric choke if needed
PostPosted: Mon Jul 12, 2004 11:01 am
well is there a kit that i can buy and from where
