It is currently Sun Jun 07, 2026 1:24 pm
PostPosted: Fri Nov 08, 2002 10:17 am
Hey all, anyone know if this steering wheel will fit an 80 Luv?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1871821784
PostPosted: Fri Nov 08, 2002 12:27 pm
I dont think a factory chevy steering wheel will fit a luv. I recently bought a Grant steering wheel for my truck to replace the original. It was cracking and the plastic horn cap was badly deteriorated. The grant wheel i got isn't as deep as the original and has a smaller diameter so i can get it and out of the truck a little easier. All together i spent about 80.00 for both the wheel and adapter kit. its an easy install.
PostPosted: Fri Nov 08, 2002 2:08 pm
I also have a grant wheel on my truck that has been on it for years. I love it.
03Cobra
PostPosted: Fri Nov 08, 2002 3:51 pm
Where did you get the adapter kit?
PostPosted: Fri Nov 08, 2002 4:46 pm
Grant sells specific adapter kits for each application. you can look it up on the grant website. I got my wheel thur NAPA auto parts. i dont know the part # , its not on my reciept. I ordered a shallower st wheel than stock, so i had to bend the blinker lever forward a little bit.
PostPosted: Fri Nov 08, 2002 7:06 pm
Nope, won't fit! I am also another Grant customer! I had one of those wheels in the auction on my s10 blazer, but I know that doesn't help you at all. :roll:
PostPosted: Sat Nov 09, 2002 5:59 pm
OK thanks everyone!
PostPosted: Sun Nov 10, 2002 2:09 pm
I just had a thought. Is there an adapter out there that would adapt the steering wheel in the link above to a Chevy LUV?
PostPosted: Sun Nov 10, 2002 5:59 pm
Sorry man, but no. The wheel has the splines that go onto the steering shaft built into the back of the wheel. The adaptor works as the same thing as then the after market wheels bolt onto that as they are a universal wheel. If there was some kind of adaptor the wheel would be about 4 or 5 inches closer to you and would be pretty much into your chest! If you REALLY wanted to have this wheel, I think the only thing you could do (way too much work and probably unsafe) is to find a GM steering shaft and cut the splined part off and have it welded to the LUV steering shaft. I don't even know if that would be possible. They probably are different diameters. Sorry
Users browsing this forum: Baidu [Spider] and 14 guests
