It is currently Fri May 29, 2026 10:00 am
PostPosted: Fri Aug 22, 2025 2:06 pm
Ok, I give to the luv gods. Can't shift with 4x shifter to 2h. It will go from 4h to 4L. Pulled shifter out and I can manually move the left lever forward to put into 2h.
Does that mean detent spring? Will I have to pull transfer case?
Once in 2h If i reinstall the shifter I can't move to 4h either
Users browsing this forum: Baidu [Spider], Google [Bot] and 61 guests
