It is currently Tue May 14, 2024 10:40 am
PostPosted: Thu Jun 09, 2022 10:16 pm
1978, neither gauges are working. Gen light is on.
Cleaned up the fuse box, Got it working for a minute, gen light stayed on and went dim, then got bright and everything quit working again
I cleaned the connection on sending unit and around the sending unit (as much as I could), didn’t seem to solve it.
PostPosted: Fri Jun 10, 2022 4:11 pm
See if it blew any fuses. Also on top of the fuel tank, see if any of the wires are loose.
PostPosted: Fri Jun 10, 2022 8:56 pm
Replaced all fuses. All connections top and bottom of fuse block have been cleaned from if/any corrosion
Also cleaned the connection on fuel tank
PostPosted: Tue Jul 19, 2022 8:28 am
I'm not sure what's going on with the fuel gauge/sending unit. Perhaps someone can chime in on that.
Regarding the temp gauge, there's a sensor on the bottoms of your intake manifold. Check the connections on that.
If that doesn't work, you could replace the sensor (those should pretty inexpensive to buy).
