It is currently Fri May 29, 2026 10:01 am
PostPosted: Tue Jan 11, 2022 4:31 pm
So the only thing my LUV needs to be reliable is a new master cylinder (brake), I've ordered 2, and the fitting for the front should have the banjo bolt setup for the double brake line attachment, every time I order one, it comes with the single line fitting like the rear brake reservoir. What's up with this??? I can't reuse mine and swap it, it's too worn, how do I find the correct fitting to swap on the new master cylinder since I see I will not get one with the correct fitting on it? Is there a place to get just the fitting so I don't have to keep returning and reordering cylinders?
Users browsing this forum: Google [Bot] and 54 guests
