It is currently Mon May 25, 2026 3:02 pm
PostPosted: Sat Feb 29, 2020 6:21 pm
I am working on a 77 Luv. replaced the head gasket, and now it doesn't have a spark, but the coil tests out OK. Does anybody have a cover for the fuse box?? The coil seems to test out ok based on the ohms needed. I connected all of the wire back the correct way. It does have a toggle switch underneath the key in the cab, what is this for?? The wires have been taped with black electrical tape, so I know someone has worked on it before. Swinedog, DeKalb IL
PostPosted: Fri Mar 27, 2020 5:11 am
Cleaned everything really well, including the ignition. Starts and runs! Dale
Users browsing this forum: No registered users and 59 guests
