It is currently Mon May 25, 2026 3:02 pm
 Post subject: I need a motor
PostPosted: Wed Jan 01, 2020 2:02 pm
I just pulled the exhaust off of my 1.8l yesterday and found a gaping hole in the side of the block. Does anyone know where I can get a block on the cheap? I cant put alot of money into this truck. From what I've read the 1.8, 1.9, and 2.0 are interchangeable. Any help with the parts search would be greatly appreciated.
 Post subject: Re: I need a motor
PostPosted: Wed Jan 01, 2020 2:39 pm
Talk about bad news! Where are you located at?
PostPosted: Thu Jan 02, 2020 10:06 am
I live in Minden Nevada but spend half my time in Nampa, Idaho with my son.
PostPosted: Thu Jan 02, 2020 3:40 pm
I'm in northeast Nebraska and have one I pulled out of a 78 LUV, thought maybe I could help you out. Thinking you should be able to find something closer. Good luck with your project!
PostPosted: Sun Jan 05, 2020 1:35 pm
Thanks for taking the time bud.
PostPosted: Sun Jan 05, 2020 9:51 pm
Post this on the Chevy LUV group on Face Book also. You're lucky to have two locations to find one. ID might be better than NV. It seems more LUVs are up there. Good luck. They're out there. It just might take a little time to find one, but there are plenty out there.
PostPosted: Mon Jan 06, 2020 1:46 pm
Also a bit out of the way but I know someone with a 79 1.8 available in northern Colorado here.
PostPosted: Tue Jan 07, 2020 11:25 pm
I can look in the junkyard down here in Vegas if you want. HMU with a message if you want my contact info.
Joshua T
:signlies
PostPosted: Tue Jan 14, 2020 6:19 am
i have a name and number for a guy that rebuilds block and he has a few in stock. I'm actually waiting on one right now i blew up my block that i had a turbo on :( it should be back up and running in a month. but he is not a cheap option. but figured id show it out there
Chad Frigon
