It is currently Wed Apr 24, 2024 8:00 am
 Post subject: Weber float level
PostPosted: Tue Dec 05, 2017 9:59 am
Just replaced the top on my Weber 32/36. I set the float to 40mm just like the old one, all the specs say to set to 35mm. Any suggestions on what will work best.
76 LUV
 Post subject: Re: Weber float level
PostPosted: Thu Jan 18, 2018 2:03 pm
I found some info and set it to 35 mm to the bottom of float. Had it set to 15 mm to top of float.
76 LUV
PostPosted: Mon Feb 19, 2018 1:03 pm
Reset my float to 39 mm to the bottom as per another member. I hope this helps.
76 LUV
