It is currently Tue Jul 28, 2026 2:03 pm
 Post subject: Spark Plugs
PostPosted: Tue Feb 13, 2018 4:13 pm
Looking for the proper spark plug. The book says NGK BPR6ES. All the parts stores say these are the wrong plugs. I have been using AC Delco R44XLS.
76 LUV
 Post subject: Re: Spark Plugs
PostPosted: Tue Feb 13, 2018 5:38 pm
The Chevy parts manual calls for the R44XLS
PostPosted: Wed Feb 14, 2018 7:51 am
I’m trying to get my gas mileage back up to 28 mpg. I rebuilt my carb replaced the plugs, rotor, cap and new plug wires and now my gas mileage is down to 23 mpg.. Looking at different spark plugs hoping that would make a difference. I'm running a stock 1.8 with a Weber 32/36 and Pertronix ignition with Accel 1.4 ohm coil with resistor still in place. Looking for suggestions.
76 LUV
PostPosted: Wed Feb 14, 2018 11:03 am
I am not a fan of a.c. Plugs. I usually run the autolite equivalent..
PostPosted: Wed Feb 14, 2018 11:17 am
With the Pertronix ignition you probably want a hotter plug.
I'd try the plugs and gap for an 85 Trooper.
PostPosted: Wed Feb 14, 2018 2:16 pm
Looking at the Bosch 6736 fine wire that's pre gapped.
76 LUV
PostPosted: Wed Feb 14, 2018 7:37 pm
Found a set of NGK BPR6ES-11 #7133 in with all my spare parts. Going to install them this weekend.
76 LUV
Users browsing this forum: No registered users and 65 guests
