It is currently Sun Jun 07, 2026 2:30 am
 Post subject: Trans change
PostPosted: Sun Oct 06, 2002 1:43 am
I found that LUVs did not come with 5 speeds. After a long search, I got one out of a 79 Izuzu Mark IV car. It fit perfect and I only had to change the input shaft to a 86 Izuzu Pup. Hope this helps some of you that want to stay stock.
PostPosted: Sun Oct 06, 2002 11:43 am
Good info. I put a 5-speed in mine out of a diesel but it didn't handle much abuse. I broke it within a year. Maybe it was bad when I got it, or maybe I was real abusive?
But I would think that the route you took would be better and last longer.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Mon Oct 07, 2002 3:04 am
I have not been too easy on my LUV. I use it daily for my job, so it gets a workout. I have had my LUV for about 8 years relatively trouble free until last week when I started losing water. No leaks, none in the oil, and when I pulled the head, no blown gasket. I hate to think that the head cracked, but what else could it be?
PostPosted: Mon Oct 07, 2002 11:04 pm
maybe the radiator cap is bad ?
PostPosted: Tue Oct 08, 2002 11:18 pm
great info on the transmission.i've been wondering if theres a 5 speed that will fit it.i think my runs a little too high at about 80.what kind of adapter do you have to get off the pup.this is going to be my next project
 Post subject: trans change
PostPosted: Tue Oct 08, 2002 11:27 pm
Hey Bob, I checked the cap and it was fine. Not losing any water outside that I can see, but having to fill radiator every day ( about a gallon maybe less ). Pulled head, 3 cyl light, 1 dark.
The trans I used was out of an 79 Izuzu car MarkIV. Only thing from the PUP was the front input shaft
PostPosted: Tue Oct 08, 2002 11:49 pm
thanks for the info.it will come in handy.god bless this site its going to save me alot of time looking for things
PostPosted: Wed Oct 09, 2002 5:28 pm
Hey bcg187, as long as your LUV has the cable operated clutch the trans is a direct bolt in. You will need an input shaft from a PUP, I think I used a 83.
This is indeed a great site, I have stumbled along for many years alone. Now I have company. Thanks for the great site LUVtruck.com.
 Post subject: Re: Trans change
PostPosted: Wed Oct 09, 2002 5:41 pm
yep now we can all stumble together :wink: :lol: j/k i LUV this place!!!
PostPosted: Thu Oct 10, 2002 1:45 am
hey mouse53.i haven't never swapped a tranny before.i have a 80 4wd luv would you happen to know if i would have to change my output shaft to get that mark 4 5 speed to fit
PostPosted: Thu Oct 10, 2002 4:27 pm
Hey bcg187, I just noticed you are working on a 4x4, I have only done the swap on a 2x. Not sure about the 4x4 trans . Doesn't it bolt directly to the transfer case? If so we will need more input, anybody else done this?
mouse53
PostPosted: Fri Nov 01, 2002 8:32 pm
Im pretty sure you can get a 5-speed out of a longbed I testdrove a longbed it was pretty fast for a 4 cyl, but you really had to rev it up to hit 5th,oh yeah it was also a really big rust bucket. :?
1975 luv V-8 muncie 4-speed
