It is currently Sat Jun 06, 2026 10:37 pm
PostPosted: Wed Nov 23, 2016 3:16 pm
Does anybody have an extra ignition switch with a key they want to part with?????
The luv now has an electrical issue and I'm going to start there first. Don't know what happened the truck was running fine then we shut it off and it didn't want to start. Sounded like a dead battery ( STARTER CLICKING ) but that was not the case. Checked power at the fuse box and when the key is turned to the on position the voltage at the fuse box drops in half ?????
Anybody had this issue before???
PostPosted: Wed Nov 23, 2016 6:42 pm
I've seen them on ebay, but rarely. If you have an actual locksmith in town, worth a try. Had one repaired on a Datsun 510
PostPosted: Thu Nov 24, 2016 8:35 am
O'Reilly's can get them. Ordered on last night and it will be here Friday. It even comes with a key.
PostPosted: Thu Nov 24, 2016 10:25 am
Rather then replace switch they make a mechanics push button start jumper for diagnostic purposes. I would try that first to see if it's even your switch. I've seen bad battery's with bad cell show 12v+ however cannot handle load. Did you load test battery?
I have forgot more than most will ever know.
PostPosted: Thu Nov 24, 2016 7:41 pm
I have a couple of them with one key each.
PostPosted: Fri Nov 25, 2016 10:40 am
Thanks Don, but O'reilys can get them and it should be here today.
PostPosted: Fri Nov 25, 2016 1:45 pm
Sure.......
PostPosted: Sat Jun 10, 2017 10:54 am
Part # CS323L Bwd 55.99 anytime O'Reilly Auto
