It is currently Sat Jun 06, 2026 10:38 pm
 Post subject: Air conditioner
PostPosted: Fri Apr 22, 2016 5:47 am
So my AC doesn't work at all, the compressor pulley is pretty much locked up and doesn't have a belt on it. i was thinking about just buying a whole new compressor to see of that works. I just need some advice on a brand and size. And maybe some tips on the switch!!
79 4x4 Mikado
 Post subject: Re: Air conditioner
PostPosted: Thu Apr 28, 2016 7:33 am
Still need some help
79 4x4 Mikado
PostPosted: Thu Apr 28, 2016 8:08 am
Compressor failure can contaminate the entire system with debris that will damage or ruin your new replacement compressor. I would have the evaporator, condenser, and lines professionally flushed before replacing or rebuilding your compressor. Then, be sure to use a new dryer (accumulator) when putting it back together.
There are DIY flush kits, but I took all my components to a local shop, connected them together, and asked them how much they'd charge me to use their pro equipment and flush it. $20 and done! I couldn't have even bought the DIY supplies for that.
Don't recharge the system without THOROUGHLY vacuuming it down.
Do you have a source for R12, or do you plan to use a substitute?
I can't offer advice on compressor brand and size--but maybe this will help get the conversation started.
PostPosted: Thu Apr 28, 2016 4:55 pm
If there's indeed a possibility that the compressor grenaded, I'd add a new expansion valve to Jack's list.
Tom
PostPosted: Sun May 01, 2016 6:19 am
Alright I'll give that a look. Thanks guys!! I'll post in this thread if I make any progress
79 4x4 Mikado
PostPosted: Wed Jun 01, 2016 7:00 am
if you still need help with this i just pulled my working ac compressor out today, you can have it for whatever the shipping would cost.
Overkill is underrated!
