It is currently Sun Jun 07, 2026 1:46 pm
 Post subject: engine rebuild
PostPosted: Fri Apr 01, 2016 12:25 am
recently had a mishap with my cam gear coming off. First question is can i put a cross flow head on my non cross flow 1.8? its a 75 with the exhaust and intake on the same side. if not where can i get a new head and possibly pistons. i know the questions are gona come flying at me but the answer is i dont know because i havent taken a look beside removing the inspection cover and seeing the cam gear loose. i think one of the dowels sheared but not sure if the valves bent. gona pull the head and check soon. just tryna prepare for the worst case scenario.
thanks from hawaii
 Post subject: Re: engine rebuild
PostPosted: Fri Apr 01, 2016 6:53 am
here is a little info from when I rebuilt a 76 motor about 1 year ago. Some of the gaskets are getting harder to find.
I do have at my disposal a 1973 motor (tore down but complete)and trans with 28000 miles on it I will not sell just parts its all or nothing.
The reason I did not finish rebuilding the 73 motor was that I can find most of the gaskets but not all of them.
PostPosted: Wed Apr 06, 2016 12:46 am
sorry i know you are trying to help but why would i buy something that cannot be completed? anyone else??
PostPosted: Wed Apr 06, 2016 12:47 am
i am curious though, which gaskets could you not find?
PostPosted: Wed Apr 06, 2016 1:10 am
Interesting question. I don't know enough about the early engines to know if the head can be swapped. I'd also like to know the answer and hope someone more knowledgable will chime in.
PostPosted: Wed Apr 06, 2016 12:35 pm
Just by looking at the difference of the timing chain covers I would say they are not interchangeable.
PostPosted: Wed Apr 06, 2016 2:43 pm
the one gasket that I could not find was one that went between the block and for lack of terms intermediate pan.
it is flat with a hoop on each end. I do believe that if you find the right place it can be made.
I found listings for full gasket sets but no one had them.
PostPosted: Wed Apr 06, 2016 3:57 pm
I assumed that the ones with intake and exhaust on the same side were that way because there were pushrods on the other side. And the ones with cross flow heads would be OHC engines (no pushrods). Is that correct?
PostPosted: Wed Apr 06, 2016 4:57 pm
The American early and late G180 are both OHC.
PostPosted: Thu Apr 07, 2016 1:22 pm
yup mine is OHC. I actually have never even looked at the block configuration/ differences between the years...duh sometimes the simplest answers are the hardest to find. Anyway, I got lucky. The timing gear bolt and retaining washer backed off enough to allow the cam to stop and the crank to spin. Im assuming that the cam stopped in a "sweet spot" where none of the valves were open enough to hit the pistons. I never heard a tap, bang bliff or even kerpow during my unsucsessful starts or while it was running. Engine gods were on my side.
PostPosted: Thu Apr 07, 2016 4:53 pm
The early models--non crossflow heads-- the pistons will not hit the valves, plenty of clearence. The later crossflow heads however will contact the valves with a timing chain failure.
The heads will not interchange because intake, carburator, etc are on the other side of the block. Also the later head timing chain is driven with a single chain from the crank shaft, the early ones like you have, the camshaft is driven by two different chains--one to the jack shaft that drives the oil pump and distributer, other from there to the camshaft.
Make sure you tighten the cam sprocket bolt to the proper torque after you reset for the proper timing. This depends on it's torque by friction to drive the cam, not by the dowel.
PostPosted: Thu Apr 07, 2016 10:50 pm
roger that! thanks for the input guys. oh btw I also bought a direct replacement hitachi carb from a place in cali called carburetor exchange. rebuilt like new and only $250 ish. runs like the gas sipping little sucker it is. awesome
Users browsing this forum: Baidu [Spider] and 65 guests
