It is currently Sun Jun 07, 2026 1:17 am
 Post subject: Stock trucks
PostPosted: Mon Nov 09, 2015 12:14 am
What motor will bolt up to a stock 1980 1.8 4speed 4*4 just wondering what I can put in my luv
 Post subject: Re: Stock trucks
PostPosted: Mon Nov 09, 2015 9:23 am
2.6 Isuzu. That's about the only option.
PostPosted: Mon Nov 09, 2015 10:15 am
Yep only the early rwd isuzu engines,
so the g200 1.9L basically the same you have now bored to 1.9L. Direct bolt in
the 4zd1 2.3L, carburetted, pretty much goes in as is. May need slight modifications or to use the mounts it came with but will physically bolt in
And the 4ze1 2.6L, fuel injected. You can put a 2.3 intake/carb on this engine for a much easier swap.. otherwise same bolt in as the 2.3 just bigger.
PostPosted: Tue Nov 10, 2015 9:48 am
Thanks for the information that is helpful
