It is currently Sun Jun 07, 2026 1:17 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Tue Mar 31, 2015 9:51 pm
Alright, seems like it has to be something to do with the distributor. I've installed a new Weber carb and it runs even better with the old points distributor. But with the electric distributor I'm getting the same problem as before. I've checked to see if it retards as I accelerate and it does not. It does indeed advance. Could it be I have it wired up incorrectly? A few of us have had mixed instructions on how to wire it in. I currently have the single wire that was used for the points distributor connected to the wire with the red stripe on the new electric distrutor. The black wire on the new distributor is connected to the neg side of the coil.
PostPosted: Tue Mar 31, 2015 9:59 pm
Oh and another thing I exhibited was with the filter off of the Weber and I do a hard acceleration, it gives a loud pop up through the carb barrels as it hesitates and almost dies.
PostPosted: Tue Jun 30, 2015 1:49 pm
Did you ever get this figured out?
PostPosted: Sat Jul 18, 2015 7:15 am
I'm afraid not. It recently died. I tried restarting it many times without any luck. I need to further diagnose if it is related to this issue or not. I'll get it back running then try working on this issue again. Please let me know if you have any other advise. Thanks
PostPosted: Tue Oct 13, 2015 10:46 pm
WONDERING are you still having fun w/ this Luv truck ?
I would like to say Hello as i live just south of you down here in Vallejo...50-60 min away..I do believe your the closest LUV
member to me I've seen on here :esurprised
...So I'm feeling a bit compelled to help you out being almost neighbors and all.. 8)
Let me know what you have tried & currently going on ...Who knows maybe we work something out and i drive out.
...Peace
