It is currently Sat Jun 06, 2026 11:49 pm
 Post subject: Wheel fittings
PostPosted: Mon Apr 13, 2015 12:58 am
Ok so ive been having some rims on my 1980 Luv. The 2 back wheels tuck inside the fenders, and the 2 front ones stick out, does anyone else have this issue with theirs? Can i fix it by putting wheel spacers/adapters on the back rims to make them a bit wide so they match up with the 2 front ones, that way all 4 rims look wide and alike? If so what size adapters, or frm where should i measure so i know what size to get. I posted a pic idk if you guys can notice the diffrence
Help me out, thanks
 Post subject: Re: Wheel fittings
PostPosted: Mon Apr 13, 2015 1:43 pm
The track width is wider on the front end from the factory. Something to do with stability
You could change it easily with wheel spacers if you want to
There is a dimensions diagram in the luvtruck.com info section to tell you the difference
PostPosted: Mon Jun 22, 2015 8:49 pm
Mine is like that. The front wheels stick out like 2 inches and the back wheels are tucked nicely. I noticed that a lot of trucks are like that. Not just Luvs :)
--Nathan
Hannah - '79 4WD, 32/36 Weber, and a Pacesetter header. :D
Users browsing this forum: No registered users and 74 guests
