It is currently Sun Jun 07, 2026 2:33 am
 Post subject: Gear Ratio
PostPosted: Tue Feb 20, 2007 10:37 pm
Does anyone know what differential gear ratio LUV's came with
'78 Luv 1.8, soon to be 350
'69 mustang 302
'68 lemans 455
PostPosted: Wed Feb 21, 2007 11:14 pm
Swap Specialist Mod
72-75 had 456gears
76-82 had 410gears
83-87 had 410s, 373s, and 342s sometimes.
PostPosted: Wed Feb 21, 2007 11:47 pm
Thank u. :)
'69 mustang 302
'68 lemans 455
PostPosted: Thu Feb 22, 2007 6:14 pm
Farmer Joe wrote:
72-75 had 456gears
76-82 had 410gears
The early 72-75 LUVs had that low of a rear axle ratio as a 2WD? I find that hard to believe as it's the same ratio a Trooper has but that is a 4WD vehicle which I can understand. If you had a LUV that had the automatic trans I do believe 4.10 is the factory ratio. But manual trans you would think it to be a higher ratio axle. I know 81 and up trucks like the back of my hand. The trucks with the automatic came with 4.10, along with the 4x4s and the 5-speed came with 3.73. And of course a PUP with a 4-speed (in a 2WD) came with the highest ratio axle of 3.42. I've never heard of any different ratios then that in a LUV or PUP.
Salvy
1982 Chevy LUV diesel
2.25" stainless exhaust
w/ MagnaFlow performance muffler
PostPosted: Fri Feb 23, 2007 7:48 am
My '79 has a 3.73:1 differential.
The Series 9 factory shop manual says the following:
Rear Axle Ratio 4.10:1 or 3.73:1
Front Axle Ratio 4.10:1
It seems that the 2WD's had 3.73 rear ends and 4WD had 4.10.
 Post subject: Re: Gear Ratio
PostPosted: Thu Jan 22, 2015 3:36 pm
Hi. I came here looking for answers and i just want to confirm what im hearing...
I have a 80 4x4 gas 4sp manual. Its rear diff gear ratio should be 4.10?
And my parts truck is a 79 4x4 diesel conversion (4sp manual), its rear diff should also be 4.10?
Im doing a diesel swap and hoping I don't have to swap any differentials or axles.
Users browsing this forum: Baidu [Spider] and 36 guests
