It is currently Sun Jun 07, 2026 3:53 am
PostPosted: Sat May 17, 2014 1:41 pm
Anybody have any tips on doing this, and does a certain type of paint look better than others? I'm debating painting them matte black, but am just worried it'll end up looking funny. Can't seem to find decent pictures of peoples bezels and grill painted.
So any links or info would be much appreciated, especially from those who have done it, maybe post some pics for me!
PostPosted: Sat May 17, 2014 3:18 pm
Finish quality has a lot more to do with good prep and patience than it does with high-quality paint. And you don't even have to be that patient, or talented, really.
To sum it up, If you clean the surface well, and use a few coats of primer before the matte black, you stand a good chance of making something indistinguishable from pro-level work. If you still have the patience to clear-coat it afterward, you'll quadruple it's lifetime.
Step 1, Cleaning)
This can be done with a brillo pad and some IPA
Step 2, Primer)
Prime. After the second coat dries, take some 220 sandpaper to any areas that show texture. Repeat until you're satisfied.
Step 3, Raise bond energy)
Lightly sand with 600 grit or finer, for just a minute or so. This is important. It mechanically breaks the bonds on the surface of your primed part and 'readies' the primer to accept paint. Quickly wipe down with a brand new clean rag with a little bit of IPA on it, and immediately again with the dry side of the rag.
Step 4, Paint)
Paint that sucker within 2 hours of step 3 (or skip step 3 all together because the bonds re-link if you wait longer than that). Flat black acrylic spraypaint will look just fine. If you fuck it up and it texturizes, wait for it to dry and go back to the sanding part of step 2.
Optional step 5, Clear Coat)
Start at step 3, and do step 4 with a UV-resistant clear coat instead of flat black.
PostPosted: Sun May 18, 2014 12:57 pm
agreed quality prep makes all the difference i painted my bezels and grill while i was doing the reassembly
use something like scotch brite to clean it up but dont rub it real hard and rough it up a lot
PostPosted: Sun May 18, 2014 7:33 pm
I used satin black to paint the grille and bezels on my truck and it looks really good.
PostPosted: Mon May 19, 2014 9:31 am
Step 1, Cleaning)
Step 2, Primer)
Step 4, Paint)
Thank you! This is exactly what I was looking for. Will post some pics if I end up doing it.
PostPosted: Wed May 21, 2014 12:33 am
I Painted the Bezels and Grille on my Luv with rattle cans of gloss black.
It turned out really well and still looks great a few months later.
Like others have said, paintwork is in the prep.
Scuff/sand
Clean (Water based and then mineral based cleaners)
Prime
Sand
Paint
Spend much more time doing prep than you do painting and you will be fine.
PostPosted: Wed May 21, 2014 1:38 am
If you are painting over the stock chrome bezels (or any chrome) follow the above listed instructions . BUT !! you will need to use a self etching primer .
