It is currently Sun Jun 07, 2026 3:51 am
 Post subject: Can't figure it out???
PostPosted: Sat Feb 14, 2009 10:25 pm
So i was messing with my head lights and blinker on my truck and the blinker wouldn't work on either side and in low beam the far left head light is the only one that worked. I then tried to flip it to brights on the blinker switch and the bottom fuse kept blowing. So on a whim i put a new fuse in and turned the lights on again but this time with them all on the brights they all worked but as soon as i fliped it back to low the fuse blew and none of the lights worked. Also when i turn the lights on my blinkers only light up they won't flash when i flip the switch. I appreciate any help.
Thanks
Ty
A good friend will bail you out of jail, and even better friend would be sitting in the cell with you saying how awesome that was!!!
PostPosted: Sun Feb 15, 2009 3:21 pm
Replace the right hand low beam headlight or just unplug it and see if the fuse still blows. On the turn signal problem, it may just be a bad flasher unit. Try a new one, they are cheap. Be sure and replace the correct one as there are two--one for turn signals and one for the four ways.
PostPosted: Sun Feb 15, 2009 3:23 pm
Aren't you currently rewiring the truck?
PostPosted: Sun Feb 15, 2009 6:58 pm
okay got the head light problem figured out and i am almost done rewiring, so possibly if i change those flashers solenoids my blinkers hope fully will work? Also i can turn it on low beam and high beam now and they work just fine, but when try to turn the blinkers on it blows the lighting switch fuse every time, would that be conected with the flasher solenoid and happen if they are bad?
Thank you for the help!
PostPosted: Sat Jan 04, 2014 5:11 pm
did you figure out the flasher problem? everythimg i try to use my turn signal its blows my fuse
Users browsing this forum: Baidu [Spider] and 43 guests
