It is currently Sun Jun 07, 2026 12:33 pm
 Post subject: luv wont start
PostPosted: Sun Aug 04, 2013 10:56 pm
Well the other day I was cruisin around with some buddies, shut the truck off multiple times and it fired right up. The next day I drove it to a buddies house, parked and shut it off. When I went to leave it wouldn't start. Has no spark.at coil. So I checked the regulator fuse, was good. Swapped 3 different coils and still no spark. My money is on bad points, but let's here what you guys think
I'm workin' on it
78 chassis with 75 cab
SBC
 Post subject: Re: luv wont start
PostPosted: Thu Aug 08, 2013 6:11 pm
Points or condensor could definitely be the cause. Are you getting power to the coil though? Check it just sitting key on and while cranking both. Check the ballast resistor too. Could be toast and not sending power to the coil while you are cranking it over.
PostPosted: Wed Aug 14, 2013 10:45 pm
found out the problem, and its getting fixed. the issue was the engine is a 4 cylinder and not a v8. new points and condenser and it fired up, drove into the garage to pull the engine!
I'm workin' on it
SBC
