It is currently Sun Jun 07, 2026 7:01 am
PostPosted: Fri May 17, 2013 10:04 pm
Hey all
Working on 1980 luv stock 1.8 with stock carb. leaving work and lost the idle truck would just die., but runs ok at higher speeds. I have cleaned all the jets out but still can not get it to idle. Any IDEALs or thing I may be missing. I know I should put a webber on it, but just put one on my other Luv (no Money to spend on that now, carb was no good)
PostPosted: Sat May 18, 2013 4:11 pm
Vacuum issue maybe. Check to make sure all the lines are connected and no leaks.
PostPosted: Sat May 18, 2013 4:38 pm
Make sure you have power to the "run on" solenoid with key on. Electrical connector on the carb.
