It is currently Sun Jun 07, 2026 5:22 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: my luv has no spark
PostPosted: Tue Dec 18, 2012 5:17 pm
78chevyluv wrote:
ok well thanks for all the info! im thinking i'll just rewire the fuel pump since i cant find those relays anywhere. and i wish my jeep could get stuck in the snow! ive never been able to get it stuck, especially now that its locked front and rear :D
the itty bitty tires aid the getting stuck quite a bit lol. we didnt get stuck last night but we didnt push on much farther after i started dragging the diff in the snow :lol:
PostPosted: Tue Dec 18, 2012 7:50 pm
that tends to happen with small tires. ive got some 44''s,or 37''s that will solve your problem :D
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Tue Dec 18, 2012 8:47 pm
i got another question, will a 4 speed from a 4x4 luv bolt up too my 2x4?
I'm workin' on it
SBC
PostPosted: Tue Dec 18, 2012 10:54 pm
yessir it will, i think i read something about the clutches beign a different size so bring over the clutch/flywheel. when i bought my spare engine it had a different size clutch so i went with the flywheel with the bigger clutch :egeek
man i would need a helluva lift to clear 37's i put a 32 on the back end to see how it would fit... not well :lol: mine are something like 25" :oops:
PostPosted: Wed Dec 19, 2012 12:17 pm
ok im picking up another luv for parts and i want the 4 speed so just making sure it would go in. any parts you are lookingg for i might have before it gets scraped? its a 79 4x4. and thanks again for all the info! really appreciate it!
I'm workin' on it
SBC
PostPosted: Thu Dec 20, 2012 7:50 am
pm sent
PostPosted: Thu Dec 20, 2012 12:04 pm
The 4x4 trans has the transfer case attached to it, it will bolt up but the rear mount won't fit, driveshaft won't work and a host of other issues. It is best to install a 2wd trans back in there.
STOP. what are you doing here? Fix the spark issue correctly by following the wiring diagram. Bypassing the harness will just cause more issues. A 4X4 trans will not work in a 2WD system. Do you have a repair manual to work with? If you don't repair this correctly you will cause a lot more issues. Is this truck charging? A low battery and not charging will cause all of these issues.
PostPosted: Thu Dec 20, 2012 12:11 pm
if i could find a 2wd one i would :lol: i just wanna know if it is possible and what needs to be done too make it happen
I'm workin' on it
SBC
PostPosted: Thu Dec 20, 2012 12:15 pm
and i did fix the spark issue and it is no longer bypassed. all it needed was a new coil,coil wire and the wiring to the coil hooked up correctly. runs good, but the fuel pump is dead and the carb needs rebuilt. and i do not have the repair manual
I'm workin' on it
SBC
PostPosted: Thu Dec 20, 2012 12:34 pm
I think the exhaust is in the way, rear trans crossmember is wrong, driveshaft has to be replaced, hole cut for the second shifter and I am sure I missed a lot of other stuff. I highly recommend not doing it.
PostPosted: Thu Dec 20, 2012 1:34 pm
ok well when i get the truck here ill see what has to be done for it too work. if its too much ill wait till i can find a 2wd one. thanks for the info
I'm workin' on it
SBC
