It is currently Sun Jun 07, 2026 7:52 pm
 Post subject: timing chain tentioners
PostPosted: Sun May 13, 2012 3:01 am
howdy new to this site but finaly found people into chevy luvs like me. anyway i got a question regarding timing chain tentioners. i have an 80 luv 4x4 and i currently replacing the timing chain. i have done a cuple but this one really stumps me as the tentioner is totaly different than what ive run into before. the ones im used to are small and spring loaded with a plastic lock like a screw. the one i have on my block is a cast peice that bolts onto the front of the block and is much bigger and built differently. my question is can i run the new tentioner was this some sort of desine change? its been a while since i did one and dont really remember how it goes on but with the one i got it would only be held on by the top peg wich an e clip
PostPosted: Sun May 13, 2012 10:34 am
If you can post a picture it would help. Here's what my '79 looks like
PostPosted: Mon May 14, 2012 1:09 am
hey thanks alot ur picture basicly ansered my question was just wondering if it will work and it will now the only other question i have is were can i get the oil sqirter jet? the little washer thing on the lower guide bolt my timing chain grinded mine in half is it avalble anywere new? might have a junk motor i can pull one off of but dont know yet
PostPosted: Mon May 14, 2012 5:53 pm
You could try rockauto.com. Otherwise I'm parting out this engine if you can't find one.
PostPosted: Fri Jun 08, 2012 8:22 pm
Autozone .com comes with kit on everything for timing parts 80 dollars was mine changed it about 4 months ago runs great
[color=#0000BF]luv truck 06.04.2011.[/color]
Users browsing this forum: Bing [Bot] and 69 guests
