It is currently Thu Jun 11, 2026 4:14 pm
PostPosted: Fri May 18, 2012 10:00 am
Ok I now have a new clutch master cylinder and the slave cylinder.How do I adjust the slave cylinder to the clutch fork? I know how to adjust the pedal.
PostPosted: Fri May 18, 2012 10:39 am
My 77 has a large nut, 14mm?, with a rounded end that goes against the fork. There is a smaller jam nut. Back the jam nut off to give you plenty of room. Turn the larger nut until you have just a little play between the large nut and the fork. Then tighten the jam nut. There may be specs for the play, but as long as you have a little, it should be fine.
PostPosted: Sat May 19, 2012 10:29 pm
Thanks man...I can shift now! Now I just have to wait until my brake cylinders get here!
