It is currently Thu Jun 11, 2026 10:46 am
 Post subject: A friendly reminder
PostPosted: Thu Jan 26, 2012 1:15 am
Woo! Got my truck started again after not having any time to work with it much, I finally got to use my xmas gifts, a dwell meter, and a compression tester. ^_^
Got right around 125 compression on all 4 cylinders, my spark plug gap was a little wide(I'm gonna buy a new gap meter stick thingy...) and my points were all but touching from the carbon build up, so I gaped that out to where it should be, and got some new ones from the autoparts store. so once again I have been foiled by points, let this be a friendly reminder to all of us... God damn points. :)
 Post subject: Re: A friendly reminder
PostPosted: Sat Jan 28, 2012 4:05 am
and this is why i finally chucked that dizzy and got an 85 pup electronic one
PostPosted: Sun Jan 29, 2012 10:08 pm
So an 85 pup will work in a 77 luv eh? Is that an easy swap, vaccuum tubes etc? Are there other options I can consider... aside from carrying a feeler gauge and dwell meter in the bed? :)
PostPosted: Sun Jan 29, 2012 10:35 pm
This works for me: http://www.pertronix.com/prod/ig/ignitor/default.aspx
1978 Mikado *Weber 32/36*Offenhauser intake manifold*Pacesetter header*Custom exhaust*Pertronix Ignitor & Flamethrower 40,000v coil*
PostPosted: Mon Jan 30, 2012 8:07 am
What is the part number of the Pertronix you are using.
76 LUV
PostPosted: Mon Jan 30, 2012 10:21 am
Part no. 1643 for my '78
I ordered it here: http://www.vintageperformance.com/retro ... evrole.htm
PostPosted: Tue Jan 31, 2012 1:36 am
I got a distributor out of a pup at a pick and pull for $30. It works great.
1980 LUV 2wd - More pounds in rust than torque
1994 Jeep Cherokee 4x4 - Lifted with lights ;)
PostPosted: Sat Feb 04, 2012 7:29 pm
no finagglin needed? no vacuum hose adjustments? just swap'n'go?
someone post me a picture :)
PostPosted: Fri Feb 10, 2012 8:19 am
Haruspex, were there any other parts you had to order, or was everything in the kit.
76 LUV
PostPosted: Fri Feb 10, 2012 10:59 pm
please do tell
PostPosted: Sun Feb 12, 2012 1:10 am
to swap to the electronic pup dizzy you literally pull theold one out, hook the vac advance up same way as the old one.. one wire to (+) and one to (-) on the coil.. set the timing and your good to go. the conversion took me less than an hour
PostPosted: Wed Feb 15, 2012 3:16 am
why did it take you so long did you misplace your bottle opener? :lol: :lol: :lol:
PostPosted: Wed Feb 15, 2012 10:12 am
Everything was there. Took a grand total of 10 minutes to install.
PostPosted: Wed Feb 15, 2012 12:06 pm
had to partake in some festivities half way thru :lol: :lol: and then again after i fired it up
PostPosted: Mon Mar 05, 2012 9:33 pm
New Points on, woulda' been sooner but i needed gas for the swap... and at $4.04 gal... well...
gonna ride these puppies till they poop on me, then I may decide to swap electronic or not, I've almost got these points thingamajigs down! :D
Thanks to everyone for the links and ideas!
Users browsing this forum: No registered users and 60 guests
