It is currently Sun Jun 07, 2026 11:40 pm
 Post subject: Crank swap
PostPosted: Sun Jul 24, 2011 10:24 am
will a crank from a 1.9 fit in a 1.8? The reason I'm asking is I'm buying an S10 with the 1.9 in it and it doesn't run. And I need a new crank for my 1.8. If this doesn't work then I'll have to buy another WHOLE TRUCK and I already have too many as it is.
When in doubt floor it. If you can't floor it then you've doubted yourself.
 Post subject: Re: Crank swap
PostPosted: Sun Jul 24, 2011 11:05 am
Depends if it is an Isuzu motor or not...and if it is make sure you keep the rod and main bearings out of the donor motor because it will be easier to tell if the crank had been ground..sizing should be on the back of the bearings and take them to a machine shop to be cleaned and inspected before install!
PostPosted: Sun Jul 24, 2011 11:16 am
Yes it is an Isuzu motor otherwise I know it wouldn't fit lol.
PostPosted: Sun Jul 24, 2011 4:02 pm
Some people on here don't realize that kinds stuff. If I remember correctly the 1.8 and 1.9 will interchange.But why not build the 1.9? More cubic inches and more power at little sacrifice of mileage.
The heads will interchange too.
PostPosted: Sun Jul 24, 2011 6:53 pm
Actually the 1.8 head on the 1.9 bottom end will raise compression about one full point.
