It is currently Mon Jun 08, 2026 6:51 am
 Post subject: where to start?
PostPosted: Sat Jul 16, 2011 9:45 am
hey, I degreased and washed my engine and engine compartment yesterday afternoon. had coil and distributor covered. went to start truck this morning and i dont have any spark. i dried out the distributor cap still nothing. how should i check for spark elsewhere? any suggestions?
 Post subject: Re: where to start?
PostPosted: Sat Jul 16, 2011 12:54 pm
With the key on, the + terminal on the coil should be hot. If not, work back toward the fuse box. LUV's have a weak link in the electrical system, the fusebox. The terminals the wires connect are riveted to the fuse holders. A little age and corrosion, and you get electrical intermittents. I solved mine by taking it apart and soldering the joints. Others have cleaned it with lemon juice, and others a new fuse box.
If you have 6-12 volts there, check for resistance between the + and - terminals and from the coil wire to ground. If either is open or shorted, the coil is bad. With the points open, the coil primary shouldn't be open.
Users browsing this forum: Baidu [Spider] and 46 guests
