It is currently Mon Jun 08, 2026 2:13 am
 Post subject: factory gas tank
PostPosted: Sat May 21, 2011 12:21 pm
I have a 79 that im doing some things to. ( V8 an other stuff). I noticed tthat the factory gas tank has a ton for lines or ports on top of it.. i guess what im asking is, is the one that faces toward the front of the truck, is the fuel delivery port that i hook the fuel pump to??
 Post subject: Re: factory gas tank
PostPosted: Sat May 21, 2011 1:34 pm
I dont remeber which way it faces but I do remember it is the port that is the biggest diameter. What part of Wyoming you in?
PostPosted: Sun May 22, 2011 1:19 am
Im up here in cody.. i think its the only port that faces the front or that direction. Just wanted to make sure sense it comes out of top of the tank, an thatt the mechanical pump im using will or can pull..
