It is currently Sun Jun 07, 2026 5:03 pm
PostPosted: Sat Aug 21, 2010 5:02 pm
Guys
I want to upgrade to disc brakes on my 75 base and was thinking that I am finding too many options.Would like to keep it as simple as possible.I can get access to Troopers and other Isuzus.Also didn't Isuzu make a Trooper like vehicle for Mitsubishi/Chrysler/Dodge?
PostPosted: Sat Aug 21, 2010 10:23 pm
simple: viewtopic.php?f=7&t=23178
PostPosted: Sat Aug 21, 2010 10:28 pm
Or this
http://www.luvtruck.com/Information/Brake_swap.htm
PostPosted: Sun Aug 22, 2010 7:50 am
Thanks guys! I think I will go the stock route.That way I know what I am getting!
PostPosted: Fri Apr 01, 2011 11:17 pm
if u can find one in a yard i took the disc setup off a 76 bolted right up to my 73. all u need is the dust plate the caliper mount the caliper and the rotor plus hub. everything else is the same. got mine for 75 buck for all of it 20 buck to turn rotors 18 bucks for new pads. thing stops on a dime. want pics let me know. And you DO NOT I REPEAT DO NOT need to change the master. I have looked it up at alot of shops and they all said the same. the master is all the same from 72 to 79. i used my 73 master. no hang ups and stops right now.
LIVE HARD PLAY HARDER
PostPosted: Sat Apr 02, 2011 8:43 am
This post is over 6 months old. If you took the time to look, the post 2 up from you said the same thing.
PostPosted: Sat Apr 02, 2011 11:49 pm
I think his point is that you don't need to change the master cylinder.
