It is currently Sun Jun 07, 2026 3:42 pm
 Post subject: Questions?!
PostPosted: Sat Feb 12, 2011 8:29 pm
1. so worried about previous owners neglectness to engine. without rebuilding it, and moto flush. What are somethings i can do to get rid of sluge ect. commpression is good just worried.
2.orig gas cap. have two but rubber is detierating gone. tricks hints advice.
3.Where i have a '80 1.8 longbed with a four speed, i was wanting to up the rear end gear ratio. Kinda make a fith gear. wanting the best gas milage. where can i find these gears. Advice along this thinking. Anything?
4.Need air hose scimatic. not on hood and nothing to go buy.
5.Clutch when it goes, whats the best thing for these luvs.
6.Who rebuilds isuzu 1.8. Whos the best in the west (idaho) will travle. who can i trust.
7. the tail light gasket and the frount amber gaskets. where can i find these.
8.Detailed Wire diagram. have hanys no good.
9.junkyards idaho colorado. west?
10. Complete door seal kit. or where to get matieral for restoration.
11.powersteering? Thoughts
12.where to find C.d harness kit. whats best. everything still stock.
13.rust. driver floor bad. and becomming worse in other areas. tips tricks. place where to buy floor board to weld in.
14.
 Post subject: Re: Questions?!
PostPosted: Sat Feb 12, 2011 8:46 pm
All these questions have been answered many times, use the search feature for answers. Wiring diag are in the info section
PostPosted: Sun Feb 13, 2011 6:40 am
Welcome to the site!
Look on eBay for a service (shop) manual for your year truck - they can be found for around $5.00 at times. That will help you with quite a bit of your questions. It really is a must have if you are planning to work on a Luv yourself.
Do a keyword search using the SEARCH tab in the upper right corner of your screen. Almost everything you are looking for can be found in older posts.
Good luck with your truck!
PostPosted: Sun Feb 13, 2011 3:16 pm
http://www.catb.org/~esr/faqs/smart-questions.html
Welcome to the site.
PostPosted: Sun Feb 13, 2011 11:52 pm
This is the cure to all that ails you.... :wink:
viewtopic.php?f=8&t=24201
