It is currently Sun Jun 07, 2026 7:22 pm
 Post subject: 4th gear whine.
PostPosted: Tue Feb 01, 2011 7:13 pm
Hello all, new to forum.
First car was 79 luv, exploded on me. Now have a 1980.
Stock 4 cyl and 4 spd.
I notice in 4th gear, WHILE pressing accelerator I hear a little whine. But only in 4th and only when on gas, goes away with coasting. Wondering if this is normal or a problem?
Only has 15k original miles...
 Post subject: Re: 4th gear whine.
PostPosted: Wed Feb 02, 2011 6:37 am
My 90's Toyota had a small whine in 5th gear for over a year. My clutch was slipping and it was due time to replace it. On the way home climbing up a grade on the frwy my clutch started slipping and the whine got louder. Then BOOM I was sitting on the side of the frwy waiting for a tow truck. I got it home and had a new clutch ready to install but had not made time for it. Got it all apart an noticed the clutch actually did not look broke, it was worn, but not bad. I check the rear end and sure enough the rear end was busted. Have your rear end check to see if that is were the noise is coming from.
PostPosted: Wed Feb 02, 2011 9:41 am
Thanks, I'll have it checked out. Any way a mod could move to stock trucks thread? Think I placed in wrong section.
PostPosted: Wed Feb 02, 2011 9:50 am
done
